40000 BTU heater
ZGjethro
Re: 40000 BTU heater
Post by ZGjethro »
I love that install under the seat. As far as the plumbing side goes, how do you control the flow of coolant to the heater? Were the coolant lands run under the cab floor? Do you get adequate heat from the cold blooded 230 motor? It seems to take my truck forever to get up to temp in the winter
W_A_Watson_II
Post by W_A_Watson_II »
I installed simple ball valves at the block for flow control, on and off. The hoses run back, then under the cab and up through the floor to the heater. I'm running a 318, so I can't say about the heat output of the 230.
Will
1946 Dodge Power Wagon
My 1953 Dodge M37 WEB Site
billy
Post by billy »
mine is a 318 also
just got done under dash install
just went for a nice drive with my window open all the way
nice and warm in the truck
9f outside right now
billy
Post by billy »
i havent decided where the heater switch should be
i am not cutting a hole in my dash
so i have it laying on the floor in a baggy with the wires trailing to the heater
it works but it aint perty
billy
Post by billy »
I used one of the old toggle switches that was already in the dash and didn't bother labeling anything.
I am the only one that drives it anyway
I put mine in the hole for the aux power outlet since my truck wasn't equipped with it. (Just a block off plate.)
DSC01131 (Small).JPG (102.85 KiB) Viewed 1721 times
W_A_ , sure would like to see more pics of your install, I did some measuring under my seat, and I don't see how you can get a 16" unit in there.
W_A_Watson_II
This should help, Sorry I don't have more, I wasn't a picture crazy back in 2007.
http://m37.wawii.com/2007.4.shtml
Will
That helps a lot!
Thanks.
w30bob wrote:40,000 BTUs? Are you guys planning on roasting hot dogs as you drive around???
Sweet install!
Thanks for the pics!
later,
That's a great idea, another M-37 food truck!
