Map light bulb??
Map light bulb??
Anyone know the bulb # that the map light uses? My bulb has "T308" on it ,, can't find it.
Re: Map light bulb??
Mine is the same as the blackout lamps.
Bulb # ?just me wrote:Mine is the same as the blackout lamps.
Where the heck can I find a list of the bulb types used on these trucks?
Good question.
Garbee had this (brief) list posted on his web site: http://garbee.net/~cabell/12voltconversion.htm
125106boblee wrote:Bulb # ?just me wrote:Mine is the same as the blackout lamps.
This is only good if you have the same clamshell type maplight as I have, also.
Here is a good chart of bulbs, voltages and wattages available commonly.
https://www.mcmaster.com/#light-bulbs/=1bkirvy
OK, here are some pics of mine.
- DSC01016 (Small).JPG (91.24 KiB) Viewed 1833 times
- DSC01014 (Small).JPG (118.18 KiB) Viewed 1833 times
- DSC01015 (Small).JPG (101.77 KiB) Viewed 1833 times
My bulb has two contact points on the base, and there are two springs in the base of the light. I have two of these and one had a single contact bulb in it- it contacted both springs which seems to me to be a direct short as the wires are attached to both springs (one each). The bulb that has two contacts (pic) has a single filament. This bulb came from MWM in the light.
- DSC01017 (Small).JPG (102.62 KiB) Viewed 1833 times
Double contact, single filament should be 1254, 304 & 624 from dimmest to brightest.
I would go with the LED equivalent. I think this is it. https://www.mcmaster.com/#light-bulbs/=1bkm32b
