Map light bulb??
Map light bulb??
Anyone know the bulb # that the map light uses? My bulb has "T308" on it ,, can't find it.
Re: Map light bulb??
Mine is the same as the blackout lamps.
just me wrote:Mine is the same as the blackout lamps.
Bulb # ?
Where the heck can I find a list of the bulb types used on these trucks?
Good question.
Garbee had this (brief) list posted on his web site: http://garbee.net/~cabell/12voltconversion.htm
Bulb # ?
1251
This is only good if you have the same clamshell type maplight as I have, also.
Here is a good chart of bulbs, voltages and wattages available commonly.
https://www.mcmaster.com/#light-bulbs/=1bkirvy
OK, here are some pics of mine.
DSC01016 (Small).JPG (91.24 KiB) Viewed 1933 times
DSC01014 (Small).JPG (118.18 KiB) Viewed 1933 times
DSC01015 (Small).JPG (101.77 KiB) Viewed 1933 times
My bulb has two contact points on the base, and there are two springs in the base of the light. I have two of these and one had a single contact bulb in it- it contacted both springs which seems to me to be a direct short as the wires are attached to both springs (one each). The bulb that has two contacts (pic) has a single filament. This bulb came from MWM in the light.
DSC01017 (Small).JPG (102.62 KiB) Viewed 1933 times
Double contact, single filament should be 1254, 304 & 624 from dimmest to brightest.
rickf
Post by rickf »
I would go with the LED equivalent. I think this is it. https://www.mcmaster.com/#light-bulbs/=1bkm32b
