Passenger Seat Locating Peg Photo??
Does anyone have a close up of the peg that locates the front corners of the passenger seat? I've recently discovered it's pretty important! If I have a decent photo I should be able to make a replacement. Thanks!
Re: Passenger Seat Locating Peg Photo??
Hi Andy,
Sure do-scroll away:
http://www.g741.org/PHPBB/viewtopic.php?f=3&t=6719
P.S.-I've since added a 2nd peg to mine for extra stability, using a long bolt, drilling through, passing it up from underneath, welding it in place then cutting off the excess. I can post those pix later today if you need them....
Gary,
Is it just spot welded to the top surface? I see marks on our truck from some spot welds, but no holes.
Chris P
Post by Chris P »
Yes, it's just spot welded. In fact, mine recently fell off.
Chris P
1954 M37
MVPA
MHCC
Thanks Chris. I suspect the ones on our truck fell off decades ago!
Sorry I didn't get back to this-still laying sod in the yard (see my other post in the Soap Box section); but yes, originally tacked on top-my addition included a full weld around the top circumference as well as tacking the underside for added strength-I'll add those photos this afternoon.
Gary,
I spotted the sod photos. Be careful with your back! I look forward to the photos.
Chris P
Post by Chris P »
My post that fell off is 7/16" in diameter and 5/8" tall.
Chris P
1954 M37
MVPA
MHCC
Sorry, I had to make a 60 mile round trip yesterday-will get the pix added later today or tomorrow.
w30bob
Post by w30bob »
Here you go..............
Thanks Guys!
I can see why they come off. I think we're going to make some spuds and thru bolt them from the back side.
On a side note I drove the truck home today, 11 miles. From what I can tell it's the first time it's turned a wheel on the street in a decade or two. I survived, it survived, but the cheesy muffler epoxy the PO applied burned up on the 1st hill. OHHHHH did it stink! Getting used to driving the truck will be interesting, I've never driven anything quite like it!
OK, here are my pix:
apply some 24087-done.JPG (15.77 KiB) Viewed 2089 times
trim bolt, dress weld.JPG (14.33 KiB) Viewed 2089 times
tack bolt in place.JPG (17.42 KiB) Viewed 2089 times
insert bolt thru bottom-up.JPG (16.52 KiB) Viewed 2089 times
seat peg-drill hole.JPG (16.13 KiB) Viewed 2089 times
Photos and a complete step by step repair, what more can I ask ?! Thanks :D
I've achieved 30 miles and it still works...
You're welcome on the pix; nice job on the miles! Mine just turned over 500 on the new speedo....
Good job on the fabrication Gary and congrats on the 500 mile mark.
