New member hello and some questions!
Tuko
Re: New member hello and some questions!
Post by Tuko »
got new brake hoses and wheel cyl's installed, brake shoes and drums cleaned up and reinstalled. Onto the master cyl and fuel system. sucks workin in this muggy weather were having :shock:
51 Dodge M37 W/W 4BT/NV4500
My G741 Registry Entry
Tuko
Post by Tuko »
new fuel lines run
added secondary fuel filter
cleaned primary filter
rebuilt fuel pump
new master cyl
new wheel cylinders
new rubber brake hoses
1 new battery
cleaned up some wiring
removed some decals
new exhaust
oil/filter change
all new diff oil and trans oil
filler neck hose replaced
oil pan dropped cleaned sludge and new gaskets
lubed distributer
changed air filter oil
adjusted door hinges
probably forgetting some stuff
still need to check fuel gauge, tail lamps/brake lights, horn, and speedometer. reline the parking brake, may need a water pump rebuild sounds noisy. going to try to register once the electrical stuff is out of the way. been a busy 2 weeks!! wife is getting :evil:!!
Hey Tuko,
Don't tick off the Boss-that's the fastest way to grind down to a halt! That's an impressive list of work for such a short time-I've not had any available time to work on mine, just pulling it in and out of the garage when it's time to display the flag....
WarrenD
Post by WarrenD »
Don't forget the little things, like the vents on the transmission, T-case and axles. A clogged vent will allow pressure to build as the lube heats up and it will relieve itself by blowing out seals.
Tuko
Post by Tuko »
will add that to the list!
Sal
Post by Sal »
Warren. Where's the vent on the transmission ? I got the ones on the axles, transfer case and steering box. But I didn't see any on the tranny ! :?
Sal
:mrgreen:
1954 M37 WO/W
1969 M101A1
WarrenD
Post by WarrenD »
You could be right, Sal. It's been more than a few days since I replaced all my driveline vents and my memory doesn't go much farther back than today's breakfast!! :oops:
Larry S
Post by Larry S »
Early models had the ignition filter ( to prevent radio interference ) on the firewall. It was moved inside the distributor on later models.
Larry S
1953 m37 cdn
1953 m43
1973 m342 a2(duece dump)
Tuko
Post by Tuko »
mine must have been modified. sits there but not hooked up. She got a new front leaf spring pack today, old one was sagging. waiting on parking brake band. should be here monday from MWM.
Tuko
Post by Tuko »
I'm sure many of the members on the site can look at this pic and have it bring back som memories of your restorations!
majorhitt
Post by majorhitt »
You are so right! In this photo I don't see the ignition filter on the fire wall, did you take it off already ?
Tuko
Post by Tuko »
yes, it was bypassed when I got it.
Tuko
Post by Tuko »
got the front of the truck put back together will be waiting for the spring to work on the bed, rims etc Image
Looking good Tuko.
