Troop Seat Bracket Pivot?
ez8
Post by ez8 »
where can I find a replacement for the fastener that the troop seat bracket pivots on? I'm not even sure what to look for or where to find it.
pivot pin?
pin?
I circled what I'm after in the attached jpg.
Re: Troop Seat Bracket Pivot?
You might check with John at Midwest Military. I know he makes the brackets for the jump seat so he might also have those pieces.
ez8
Post by ez8 »
Gave John a call this afternoon. The part is a special rivet which he has machines in quantities matching his build run of the troop seat so he does not stock extras.
I'm going to use a clevis pin for now, but if I can find someone with a lathe, I'm sure it could be manufactured.
The Clevis pins should work fine!
