some where I read that there is a gm 12 volt fuel sender that will work with the stock m37 tank
does any one know what the part number is
gm fuel sender part number
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
1952 M37 FARM TRUCK
1941 WC RATROD
Re: gm fuel sender part number
I used one from tanksinc.com don't remember if it was the 0-90 or 0-30 ohm.
This might be what you're looking for: http://www.ebay.com/itm/261122347319?_t ... EBIDX%3AIT
found a sender and a gauge from bosch
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
1952 M37 FARM TRUCK
1941 WC RATROD
- PFC
Hey there !
Are they 12 v or 24 ?
That's one thing I'd really like to fix...
The gauge seems to work, when I turn the ignition switch on, it runs from F to empty then back again.
I'm guessing the float is seized ?
They are resistors. Voltage makes no difference.
