gm fuel sender part number
52PLOWERWAGON
Post by 52PLOWERWAGON »
some where I read that there is a gm 12 volt fuel sender that will work with the stock m37 tank
does any one know what the part number is
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
Re: gm fuel sender part number
I used one from tanksinc.com don't remember if it was the 0-90 or 0-30 ohm.
This might be what you're looking for: http://www.ebay.com/itm/261122347319?_t ... EBIDX%3AIT
52PLOWERWAGON
found a sender and a gauge from bosch
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
LegionPiper
Post by LegionPiper »
Hey there !
Are they 12 v or 24 ?
That's one thing I'd really like to fix...
The gauge seems to work, when I turn the ignition switch on, it runs from F to empty then back again.
I'm guessing the float is seized ?
They are resistors. Voltage makes no difference.
