Engine Tolerance Question
sturmtyger380
Post by sturmtyger380 »
In my other post I had pictures of my engine after I took the head off and I don't see much wear.
The engine is a standard bore as indicated by the metal tag on the block. Standard Diameter is 3.25
My question is if I measure the bore size what are the:
Maximum out-of-round
Maximum Taper
sturmtyger380
Re: Engine Tolerance Question
Found what I was looking for:
