genny wants to be a motor
RMS
Post by RMS »
strange one today... I fired up the dark green one, ran it around for a bit, remembered I needed to tighten the fan belt. pulled up to the shop killed the ignition and was met with a hum..... turned the ignition on and off a few times, the hum persisted. I jumped out of the truck and started making my way to the battery box. when I got to the hood the hum was louder. latches off I ripped open the hood and was met by a faint smell of burnt belt. I look down at the generator and shes spinning at 1200rpm. I reached down and pushed on the loose fan belt, the genny stopped ?
I know my belt was supper loose but I cant help but think it should not do that.
Tom P
Re: genny wants to be a motor
Post by Tom P »
The Amp(current) contacts in the regulator are stuck.
Could also possibly two wire frayed together.
When you apply voltage to any Generator through the current terminal it will
Run like a motor.
Cheap way to check one also.
If it runs as a motor, it will charge as a Generator.
Tom
"47" WDX WW
"52" M37 WW
"54" Willys M38A1
"65" M35A1 WW
To Many Others
Tim Powell
Post by Tim Powell »
Never heard of such a thing!
I learned something today! Thanks Guys.
