License plate light
Gerry
License plate light
Post by Gerry »
I have to install a light for my license plate. Whats the best way to get power for it without damaging wiring harness? Also are most 12v bulb interchangeable with 24v?
Thanks.
Gerry
53 M37
Re: License plate light
Douglass or Packard connectors on truck? Most lamps are available in 6,12,24v in the same base.
The easiest way to add a wire for the plate lamp is to install a 1 to 2 wire shell on wire 21 it the splice junction above the right rear bumperette.
Gerry
Post by Gerry »
Thanks for the info
Gerry
53 M37
