i bought my ambulance and the po installed the 318
but the e brake handle and connecting rod is missing
the brake itself is still there
the t-case levers are mounted on a big metal plate that is part of the conversion
does the e brake lever go on the same big bolt that the t case levers are on?
and do i use a cable or?
m43 with 318 e-brake setup?
- W_A_Watson_II
Re: m43 with 318 e-brake setup?
Billy,
I found a couple more pictures that might help and e-mailed them to you. The M37's used a rod to connect the parking brake lever to the band mechanism.
thanks buddyW_A_Watson_II wrote:Billy,
you always answer right away with good info!
i am gonna order the handle itself and then see where i need to do something to make it work.
i gotta have a parking brake
course that means i gotta fix all these leaks first.....
Ended up inventing a bracket
Nothing that was there was going to be solid enough.
I bought a 3 foot threaded rod a clevus and i heim and fiddled with it until I had a rod that would work.
Everything is fully functional now.
Nice job! Please post a picture when you can.
