Hi all:
I'm digging through all the small parts and pieces that remain to be put on my M37.
Found 2 U-bolts. Here's the info on them.
2 u-bolts, threaded.
Both ends threaded for 7/16 NF.
1 1/2" across.... center to center of the shanks, 1 7/8" outside dimension.
2 1/2" high.
Any help or thoughts appreciated.
Jerry
480-497-9722
Gilbert, AZ.
Can anyone identify these "U" bolts?
- m37jarhead
Past Pres
Member: MVPA #26600
Member: NRA
59 M43, '76 M151A2, '86 CUCV,
'43 GPW, 416 & 101 trailers.
Past Pres
Member: MVPA #26600
Member: NRA
Re: Can anyone identify these "U" bolts?
I didn't have a chance to do a bunch of measurement, but I'm thinking they are to secure the vertical portions of the top's frame to the door sills.
- m37jarhead
ashyers wrote:I didn't have a chance to do a bunch of measurement, but I'm thinking they are to secure the vertical portions of the top's frame to the door sills.
Yep...... Now I remember where they came off.
They slip over the tubes sticking out of the bottom of the Artic top.
Once the tubes are slid into the door frame area, the U bolts are installed.
THANKS very much.
Jerry
Past Pres
Member: MVPA #26600
Member: NRA
Past Pres
Member: MVPA #26600
Member: NRA
Jerry,
Glad to help!
I just spent some time trying to figure out what the "J-bolt" was for securing the top. My truck no longer has them. Just the U-bolts you were describing.
Glad to help!
