Temp gas tank
Gerry
Temp gas tank
Post by Gerry »
I remeber reading about hooking up a temp. tank. How is this done and can you use gravity to bypass fuel pump?
Gerry
53 M37
I plan to let my fuel pump suck out of a 5 gallon boat gas can on the floor via a rigged fuel line for my test run. As for using a gravity feed, I think some folks have done that and there was a recent post regarding a mower tank? I need to test my pump rebuild so I am going this route. I have seen guys also run a fuel line right into their fender mount can. :wink:
refit1701
Post by refit1701 »
I have a small mower tank wired to the radiator support. The pump draws from that. It works great and I don't have to put much gas in to just back the truck in and out of the garage.
-John
Member of Dixie Division MVC
1953 USAF M37 wow, restored
1953 USMC M37 w/w -in storage
1967 M116A1 Pioneer Trailer
S-89 Comm box
Nickathome
An irony
Post by Nickathome »
You can call it a Gerry Can!!!! :lol: Just had to do it!!!!! 8)
KenInGA
Post by KenInGA »
refit1701 wrote:I have a small mower tank wired to the radiator support. The pump draws from that. It works great and I don't have to put much gas in to just back the truck in and out of the garage.
That's what I do. Convenient and easy to rig up and remove and fill and all that kind of stuff.
'62 M37B1- It runs AND stops!
Gerry
Post by Gerry »
Thanks all for the advice. Nickathome I am sure my wife will come up with a better name but I wont be able to print it here. :lol:
Gerry
53 M37
Gerry
Post by Gerry »
How did you guys connect the mower tank to the pump? Did you use an adapter at the pump or did you put the adapter at the end of the short rubber fuel line? Do you recall the size of the adapter? I assume the tank side is a barbed fitting to push a fuel line on.
Thanks again,
Gerry
53 M37
