horn keeps honking
macibell111
horn keeps honking
Post by macibell111 »
I just put in a new wire harness and hooked up the horn but the horn starts honking as soon as I hook upthe battery,what did I do wrong,
jordankjcm
Re: horn keeps honking
Post by jordankjcm »
I had the same issue. The horn is energized when the circuit is completed by the pressing the horn button in the center of the steering wheel. This grounds the circuit and completes it. So my issue was with the horn button mechanism inside the center portion of the steering wheel. Once I corrected that, all was good. Hope this helps.
macibell111
I will check that .I thought that I got a wire crossed at the horn but I understand that u can put the wires on either side and it doesn't matter...thanks for the info I will get on that..
macibell111
fixed it!!!!!! I had to trim down the metal stud ,it made continuous contact with the horn cap.works fine now.thanks for the help
jordankjcm
de nada. We all learn from each other! Glad it all worked out. :D
Glad to see this post, as mine sometimes blows when the wheel is turned. Now I know what to do-thanks!
