door hinge pins
vinnytruck
door hinge pins
Post by vinnytruck »
Hi Guys, Looked on the back tracks and found nothing. Soooooo how do I get the hinge pins out of the door hinge????? They are not budging, tapped them with a hammer to no progress. Can someone answer me tonite I want to work on them tomorrow. Thanks vinnytruck
vinnytruck
Tuko
Re: door hinge pins
Post by Tuko »
Your doing it right!
51 Dodge M37 W/W 4BT/NV4500
My G741 Registry Entry
jimmy_stikx
Re: door hinge pins
Post by jimmy_stikx »
Could always hit it with an oxy torch to expand the hinges and knock the pin out. I'd also use liberal amounts of your favorite penetrating oil to let soak over night before going at it again.
Re: door hinge pins
jimmy_stikx wrote:Could always hit it with an oxy torch to expand the hinges and knock the pin out. I'd also use liberal amounts of your favorite penetrating oil to let soak over night before going at it again.
Heats a good idea, use a heat gun after letting the penetrating oil work a little. I used a medium Phillips Head screw driver to start the whole she-bang, make sure your ready to catch it, my second go round I had milk crates at the ready. (They are heavy)
RMS
Re: door hinge pins
Post by RMS »
the pins on my truck were so tight that i had to drill the head off, then support the hinge with a high lift jack, add heat, then pounded out the pin with high quality punch.then due to wear i drilled out the hole and used a nut and bolt
vinnytruck
Re: door hinge pins
Thanks to all you guys who chimed in. the doors are on. soaked the hinges up with blaster last night. Used a philips screw driver (flattend the head) and it all worked out fine. #1 advice goes to M37 bruce the screw driver fit the hole and did its job. Thanks all vinnytruck P.S. pictures soon I promise...I promise.
vinnytruck
Re: door hinge pins
Glad I could help!
