Whats the little gear set in the generator for?
Could somebody tell me what the little spur gear set that is inside near the front bearing on the 25 amp generator is for? Thanks,Joe
There is an oil reservoir in the front cover, the gear slings oil to lube the front bearing. Many have been destroyed because the reservoir ran dry, most folks don't know it's there & never check the oil level. The oil seal fails letting the oil out into the generator housing, soaking the armature, field coils, brushes, & everything else in sight. Can cause some real headaches. The best thing to do is leave this stuff out, replace the front bearing with a sealed & lubed for life bearing. Later generators don't have the reservoir & oil slinger set up, these were equipped as new with sealed bearings on both ends.
