Painted my frame today
powerwagontim
Post by powerwagontim »
Got the frame, axle tubes and a bunch of other goodies painted today. Weather was perfect for working (and painting) outdoors.
Tim
Looks good....even if it is the wrong color... :lol:
No really it looks very very good!
powerwagontim
Thanks, I really like the color, which is a good thing I guess! It would suck to go through all of this and hate the color. :lol:
Tim
W_A_Watson_II
Post by W_A_Watson_II »
Tim,
Looking Awesome!
Will
1946 Dodge Power Wagon
My 1953 Dodge M37 WEB Site
Tom P
Post by Tom P »
Hi Tim,
Looks Awesome!!!
I'm liking the AF blue more .
What are we going to use for Power?
You staying with the hot water six?
Keep the Pic's Coming!!!
TGP
"47" WDX WW
"52" M37 WW
"54" Willys M38A1
"65" M35A1 WW
To Many Others
Strata Blue
Everyone else said it right, she's looking sweet! 8)
powerwagontim
Hi Tom,
Staying with a 230, I had a good T-137 engine when I started the project, went through it and did a ring job and new seals and gaskets etc, Re-built all of the exterior accessories and painted it all up. That is ready to drop in when I get some axles under it.
Thanks for the encouragement guys, I will try not to take a picture of every bolt I install!
Thanks again,
Tim
Looks like you have the frame set up like a spit. Can you show a pic of how you did the front of the fram... I'm going to be blasting and painting my frame later this spring or early summer and any advice on making it eaiser to rotate would be very helpful.
powerwagontim
It was actually quite simple and worked better than I had imagined. I cut a piece of 1/4" plate the size of the radiator mount casting. I welded a piece of pipe across the plate and sticking out past the frame horns. I ended up needing a cross brace at the ends of the frame, as it wanted to bend too much. The rear is a piece of 1/4 plate a bit smaller than the pintle mounting plate. Another piece of pipe butted to this and sticking out past the rear frame horns. Cap off the outer ends of the pipes, and weld a 1/2" nut to the back for the pivot bolts. I used a set of large jackstands to sit it on, but they can be anything, even a set of stout sawhorses. A piece of angle iron with a 1/2" hole for the pivot bolt welded onto the jackstand (or screwed onto the tp of the horses) completes the deal. I was able to rotate it to where ever I wanted and lock it by tightening the pivot bolts. This picture is the best one I have of the set-up.
Tim
http://smg.photobucket.com/albums/v246/ ... GP0453.jpg
M37UK
Post by M37UK »
I'm actually growing to really like that color after all !!
Looking good Tim !
Stu
NCmountainman
Post by NCmountainman »
:lol: Gonna be another nice looking blue truck, one of the few. Anxious to see it all together.
Ed Bennett
MVPA #31853
1951 Dodge M37 G741
1983 Jeep CJ5
1942 Chev G506 (SOLD)
Nothing is Fool Proof to a suffeciently talented fool.
