Alarms?
Longhunter7
Source?
Post by Longhunter7 »
Go to.....flamingriver.com
Electical, Big Switch with Lock Out
24 volt compatible
Best part of $80.00 and worth every penny! :arrow:
Longhunter7
Northern Illinois
63' Dodge M37-B1
Molon Lave
NRA Certified Weaponologist
W_A_Watson_II
Post by W_A_Watson_II »
Image Image
That's nicer that the two I have in my M (one for each battery).
Will
1946 Dodge Power Wagon
My 1953 Dodge M37 WEB Site
12/24 Volt
So, let me get this straight, you would need one for each battery?
Longhunter7
Main Switch
I installed the Big Switch in the ground cable that comes from the frame and goes to the first battery.
It has been working well for several years so far. :arrow:
Longhunter7
Northern Illinois
63' Dodge M37-B1
Molon Lave
W_A_Watson_II
Bruce, Yes, One on the Engine Battery, and one on the accessory Battery.
Will
Mac
Post by Mac »
Im not really worried about the shutoff on the battery, i have one of those already (not that type)....Is there any doorlock I can use? We had our landrover stolen by the kid up the street (and set on fire)....lately the dogs have been going crazy so I'm worried he may be looking for a new toy....I just want to make it a little more difficult for him, though I dont think he is smart enough to start it....
1951 M37 w\w
Marcus in NC
Lifer
Post by Lifer »
A 24-volt siren with an arming switch and a "refrigerator door" type push-button switch in the hot wire should do the trick. When you park it, the closed door will keep the circuit open. When the kid opens the door, the circuit is closed and the siren goes off. You might want to have the track coach stop by once in a whild. I'm sure he'll find a likely candidate for the cross-country team! ;)
Longhunter7
No Start
Mac,
When the electrical system is disconnected and padlocked, it is impossible to start the truck.
There is a door lock that can be adapted to work on the M37. :arrow:
Longhunter7
Northern Illinois
63' Dodge M37-B1
Molon Lave
Lifer
Post by Lifer »
W_A_Watson_II wrote:Bruce, Yes, One on the Engine Battery, and one on the accessory Battery.
The two 12-volt batteries in an M37 are connected in series to provide the requisite 24 volts. In the normal configuration, there's no such thing as an "accessory battery."
N1VSM
Re: 12/24 Volt
Post by N1VSM »
m-37Bruce wrote:So, let me get this straight, you would need one for each battery?
That depends on how your batteries are rigged and what you want to accomplish. In most applications 1 switch will do it - just depends on where you put it in the circuit.
For example, I rewired my truck so that the lights and horn are switched by the on/off switch (not the way it was originally done). I've had too many antiques kill batteries by leaving lights on (my bad) or having the horn spontaneously go off in wicked cold weather.
Mac
Re: No Start
Post by Mac »
Longhunter7 wrote:Mac,
Where can I find the door lock? or a photo and price?
1951 M37 w\w
Marcus in NC
Memphis Equiptment
Used to have one, it is the same style/type that fits the Duece/Duece & 1/2.
Someone else is bound to have the correct info? I like Lifers idea of connecting the a door button to the siren......... a track & field star in the making. 8)
I almost forgot, Trident Auto Tech in So Cal, they have lots of M-Series goodies!
Triden Auto Tech Addy
W_A_Watson_II
Lifer,
In my case, I've re-powered to a V-8. So mine has two batteries, one 12 volt to start and run the truck, and a second, that is there to run the off-road lights and winch, etc... or to allow me to self jump start. And yes I have a battery isolator in the circuit, so the alternator charges both at the sdame time, but one system won't run both batteries down.
Will
Lifer
Post by Lifer »
Ahhh! I see! Lemmee see, now. What was that my first sergeant used to say about "assuming?" ;)
