Alarms?
Mac
Alarms?
Post by Mac »
Has anyone put an alarm of any sort on an M37? If so like what? I would like to have something like that on mine, but don't know how I should go about it..
Any ideas?
1951 M37 w\w
Marcus in NC
jbxx
Alarms
Post by jbxx »
I have a low oil pressure and high temperature alarms going to the
annunciator, I dont think that this is what you mean though.
They use Murphy gauges that have variable set points on them.
My stock gauges all work though, just a good comparison and
it lets me know (audibly) if I'm not paying close enough attention.
J.B.
Re: Alarms?
Mac wrote:Has anyone put an alarm of any sort on an M37? If so like what? I would like to have something like that on mine, but don't know how I should go about it..
Any ideas?
Are you referring to an anti-theft alarm? If so, they're available almost anywyere and are pretty easy to install. I don't know if there are any available in 24-volt, though. Never had a reason to ask until now. ;)
Mac
Post by Mac »
Yes anti-theft
1951 M37 w\w
Marcus in NC
Check at your nearest full-service truck stop (Flying J, etc.). Many, if not most, over-the-road rigs have 24-volt systems, so I'd imagine that they would have the alarm you're looking for. I have no idea how much one would cost, though.
DJ
Post by DJ »
I used to have a 200lb Saint Bernard that wasnt too freindly and thought it was his truck. Worked quite well. Our 30 lb pug has a nasty bark and he also thinks it's his truck,and no one has challenged him yet!
DJ
Kill Switch
Something like a battery switch, but hidden under the dash, in an obscure location.
Mac
Post by Mac »
I would more like to know when someone is out on it...I don't think someone will be able to steal it, but I don't want anyone messing around in it either....
1951 M37 w\w
Marcus in NC
DJ
Post by DJ »
A big dog will take care of it
N1VSM
Door locks?
Post by N1VSM »
Have you considered door locks? That would at least keep the intrepid 8 year old from rolling it down a hill (invariably into a vehicle infinitely more expensive).
N1VSM
LoJack
Post by N1VSM »
I just got an answer from LoJack - of COURSE they have a product for us :) It's only $870 for one truck (24 V), cheaper per truck as you do more.
I'll pass :?
Re: LoJack
N1VSM wrote:I just got an answer from LoJack - of COURSE they have a product for us :) It's only $870 for one truck (24 V), cheaper per truck as you do more.
I'll pass :?
That is a hoot! 870 bucks!
Mac
Post by Mac »
Ouch! A big dog sounds better than $870 to me!
What kind of locks could I use? I would like it to look as original as possible....
1951 M37 w\w
Marcus in NC
Longhunter7
Lock
Post by Longhunter7 »
I installed a battery cut off switch in the negative cable that goes to the battery.
It seves two purposes. First it allows you to disconnect all voltage out of your truck wiring.
That is a good idea from a safety point, if your wiring is original.
Second, the switch I went with is heavy duty and has a provision for a padlock.
It doubles as a anti-theft device. 8) :arrow:
Longhunter7
Northern Illinois
63' Dodge M37-B1
Molon Lave
NRA Certified Weaponologist
I didn't know that they came with a locking option? Good information!!
