Paint color question
CGarbee
Post by CGarbee »
Great Guntruck photos!
It looks like I'll have to update the page on my website as you've got some here that I don't have in my collection... :)
As far as the color of "stock" trucks, we've discussed it in some other threads concerning the differnces in shade (color) between the current FS595B 24087 and the FS595 24087 that was in use in the '60's (and with subsequent changes up to '84 when FS595B was adopted).
In order to get the "correct" shade of green for a truck used from this period, one would want to specify FS595B 24084 or 34084 (semi-gloss and lusterless, respectively). The current specification FS595B 24084 is actually the same COLOR as the previous FS595 or FS595A 24087.
A much more detailed description of the changes in specifications and colors can be found at:
http://www.steelsoldiers.com/index.php? ... ic&t=15549
Honestly, the variation in one vehicle to the next when parked in a line at a motor pool (including the one right behind my office) from just environmental factors are such that even with vehicles sprayed from the same batch of paint, you get different shades... Add in the factors that have been mentioned earlier, and I personally wouldn't sweat it too much trying to get a "perfect" color match...
'53 USMC M37 w/Cummins 4BT
'64 XM708,
'51 M38
http://www.garbee.net/~cabell
peter e mark
Post by peter e mark »
But tell me, what type armor plating did you use? Was the floor of the bed covered?
1952 M37 W/W
rixm37
Post by rixm37 »
SO was Wild Honey and Daughter of Darkness both black?
rixm37
Post by rixm37 »
Now I feel much better about my truck's odd shade of color and the fact I have not been able to match it so there is different shades mixed in.
uglyranger
Post by uglyranger »
Colors of the vehicles changed due to availability of paint. Aviation assets could get green OD paint, truckers couldn't. One time I traded the services of my 5 ton wrecker to pull an engine on a chopper for 90 gallons of OD green paint. We could usually get black. The painter would us black mixed with OD to make it go farther.
The floors were covered with ammo and the gunners stood on the ammo cans. Here is a picture after an ambush with a 5 ton gun truck to give you an idea of what it looked like inside a gun box.
rixm37
Post by rixm37 »
Wow Uglyranger you have an excellent collection of photos. Your paint story is great. You used what you could get. Thanks for sharing .
This is my last entry until next Monday. Me and the missus are going to my nieces wedding in New Hampshire should be fun. Probably not able to find a computer SO see you next week. :)
