valve seats repaceable?
- SSGT
Hello weekend engine rebuilders, and todays question is : Are the valve seats the replaceable type, or must I pull the engine out and have the block cut? Thank You, Peter Mark
1952 M37 W/W
- SSGT
Thank You rixm37, I am happy at least the exhaust valve fuction can be restored without removing the engine. Are you familiar with replacing these seats? Is it , in fact, something that can be done in the field by people like KNATTRASS and me?
1952 M37 W/W
- SSGT
The only song I hear when working on the M is money, money, money.... we put a hard press on here last week to get onto rebuilding! We installed the cab yesterday for the final time after spending a few days installing the mechanicals -wiring, brackets, floor boards... We had the wheels blasted, we 2 coat epoxy/acrylic enameled them and took them to the industrial tire guy to install the new tires. Z got all the wiring and cables connected last night. We had found some small 24v clear led lights for back ups and a rear cargo lamp. Big disappointment in the renu'd fuel tank thou - we noticed some rust on the edges and the coating was peeling around the rear drain so it has to come out again.
- SSGT
Good Lord, You are certainly involved in a full restoration ! When do you find the time to do all this? Do you sleep? Are you nocturnal? A vampire maybe, that must be it...All joking aside ,(at least for a moment) I certainly would like to see your truck when your done...Peter
1952 M37 W/W
- SSGT
