Front Turn Signals
NCM
Front Turn Signals
Post by NCM »
Has anyone used something like these as front turn signals?
http://www.oshkoshequipment.com/product ... ight-Front
Id like to replace the front blackout lights with these, but they look like they may be a little to big to physically fit up there. Does anyone else have any experience with them?
What else have you used?
isaac_alaska
Re: Front Turn Signals
Post by isaac_alaska »
that's what i'm putting on my truck as soon as i come up with the $108 to get a set
Isaac
Fairbanks, AK
Civilian WM300 on DC3 tires
'52 M37 on 11x16 Michelin
Photo Gallery
I've seen one or two M37s with those lights, but didn't pay attention to how they were mounted.
I use the standard front markers with amber lenses:
http://www.g741.org/PHPBB/viewtopic.php ... ber#p33041
I have the stock front lamps with clear lenses and amber bulbs. Very bright and easy to see.
Just my two cents, not a fan of the new larger front and rear lamps, led or not. that being said, I used amber on the front and full red Gamma Goat on the rear, they all flash as well as directional lamps and stop lamp too. I am going to try and post a pic of both.
took me a minute to put my brain around upload
Amber Front Marker Lamps One.jpg (97.26 KiB) Viewed 2808 times
Gamma Goat Rear Lamps Two.jpg (81.84 KiB) Viewed 2808 times
NCM
Post by NCM »
Thanks everyone. I ended up ordering the larger, modern lights. I like the high visibility factor.
52PLOWERWAGON
Post by 52PLOWERWAGON »
i have orange gama goat lenses in the front and m35 tail lights in the rear
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
I have not seen the orange/amber Goat lenses, where did you find them?
52PLOWERWAGON
swap meet only ones I ever seen too
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
JBizal
Post by JBizal »
Midwest Military carries both full red and full amber lens to fit the stock M37 light housings.
John
Hi John, I think I thought you might have 'em?
NCM
Post by NCM »
I'm in the process of wiring the turn signals with the signal stat 900. Everything seems straightforward, except for the power source. Looking at the wiring diagram, I think that I need to re-direct the service stop lamp wire (#22) into the grey/black brake wire on the signal stat. I also think I need to tap the stoplight switch feed wire (#75) as the power source for the signal stat via the flasher. Can anyone who has installed the signal stat confirm this?
I am soon to try to get my turnsignals to work, have an old Signal Stat 600 there now. I live just south of you in Rock Hill, maybe we can get together one of these days, and you can offer me some guidance on my signals. I have tried to PM you, not sure I am able to get it send to you.
NCM
Post by NCM »
Nam Vet,
I didn't receive a PM from you. Happy to meet up sometime.
