floating gears
52PLOWERWAGON
floating gears
Post by 52PLOWERWAGON »
does anyone ever float the gears in their transmission
if so how do you do it
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
Re: floating gears
What do you mean "Float"?
If you mean shift without the clutch, same as any transmission. match input to output speed and ease the shifter lever. If your tower is worn out, it ups the ante some.
isaac_alaska
Re: floating gears
Post by isaac_alaska »
My tower is worn to the point that it's prett hard to get it out of second without touching 1st. It's high on my list of things to address. Makes it hard to float the gears. There's really no reason to though, the clutch is fun ;)
Isaac
Fairbanks, AK
Civilian WM300 on DC3 tires
'52 M37 on 11x16 Michelin
Photo Gallery
52PLOWERWAGON
Re: floating gears
Isaac mine is very worn too, I have found that if I give the shifter a light slap forwards it will come out of second go into neutral then I have to move the shifter over to the reverse lock spring without pushing it in then push the shifter forward
after I figured this out i haven't hit first while up shifting since
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
isaac_alaska
Re: floating gears
I do the same thing! Hahaha the tricks of these old trucks.
Isaac
Fairbanks, AK
Photo Gallery
Re: floating gears
Lighter oil than GL4 90wt helps, too.
isaac_alaska
Re: floating gears
I do need to order up some synthetics and redo my diffs, transmission, and T case. Extra horsepower is a bonus!
Isaac
Fairbanks, AK
Photo Gallery
Re: floating gears
Hey Travis,
Floating gears or speed shifting just takes a little bit of practice and patience. It will take you a bit to get the feel of ground speed to engine sound / RPM level but once you figure that out it is super easy.
I drove large trucks for a while and would only use the clutch to start forward motion. Upshift and downshift are easily done by matching your RPMs to ground speed.
Re: floating gears
Yeah 5 years behind a 13speed roadranger tends to make it second nature.
Re: floating gears
The good old days 379 Pete day cab with a Big Cam Cummins and 18 speed Eaton Fuller. Man that brings back some memories.
