timing chain
bobcat1/178th
timing chain
Post by bobcat1/178th »
how much flex or movement should a military (double roller) timing chain have. its currently off the engine so im seeing if serviceable.....
M60TC
Re: timing chain
Post by M60TC »
If the chain was still on the engine you turn the crankshaft clockwise so that the top span of the chain is tight. If the amount of slack in the lower span is greater than three-quarters of an inch, replace the timing chain. See TM 9-1840A Ordnance Maintenance manual. Hope this helps
Don
Re: timing chain
I would replace the chain and sprockets since they are already removed from the engine.
These items are relatively inexpensive and if you plan on driving your truck for a long time it would money well invested. Make sure to look at the alignment of the oiler tube when you reinstall the timing gear parts.
52PLOWERWAGON
Re: timing chain
Post by 52PLOWERWAGON »
where is the oiler tube located
cause I didn't see one :shock: :?
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
Re: timing chain
The tube is located behind the large upper gear and comes down to the right hand side, to oil the bottom gear / chain area.
52PLOWERWAGON
Re: timing chain
ok ill look there :)
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
52PLOWERWAGON
Re: timing chain
found it :)
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
