i need more power
W_A_Watson_II
Re: i need more power
Post by W_A_Watson_II »
Ray's Site (used to) have the manual along with the kit, but I see he's out of that business. VPW might have a kit by now.
Will the stock tranny mate to the dodge 318 bellhousing ? - Yes to the Mechanical Bellhousing, but there will be some linkage modifications required.
And do I really need a hydraulic clutch ? - Nope, it was my choice and added to the complexity of the conversion.
Does the radiator retain its stock location ? - With a Mechanical Clutch, yes.
Will the stock bellhousing bolt up to a 318 ? - No I don't believe so.
Will
1946 Dodge Power Wagon
My 1953 Dodge M37 WEB Site
52PLOWERWAGON
Post by 52PLOWERWAGON »
so ugly truckling is out of business ? :shock:
ill get a hold of vpw today and see if they have a kit :)
otherwise who else would have one ? :?
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
52PLOWERWAGON
update vpw does have a motor mount kit for 250$ 8)
now all I have to do is convince my uncle to help me pull the conversion :?
RMS
Post by RMS »
52PLOWERWAGON wrote:thanks so any dodge w/a318 and a manual tranny will work? correct?
ya you could ....any sb can be made to fit but I gotta ask what your intention is for the truck. a camed out 318 with a np435a ,d or L
is doable for a highway cruzer but would never work for rock crawler or plow truck.
52PLOWERWAGON
more of a daily driver than anything
but I love to play in the mud and I wouldn't mind trying rocks someday
52PLOWERWAGON
52PLOWERWAGON wrote:update vpw does have a motor mount kit for 250$ 8)
I think I convinced him all it took was that I would pay him good to make me a custom wiring harness :)
he said um o.k. 8)
RMS
Post by RMS »
52PLOWERWAGON wrote: more of a daily driver than anything
with the 318 having a piddly 3.31in stroke and the lowest 1st on a np435 being 6.69 to 1 you may find that low is not low enough.
and 1to 1 is still 1to1 and the 5.83s life expectancy after 4000rpm declines sharply
W_A_Watson_II
I have more than enough Power with my 318 to brake axles. And the Granny 1st NP435 crawls decent.
It all depends on what you want to do and how you plan on using/abusing it.
Will
52PLOWERWAGON
then it will have to just be a crooser :| should still be good in mud right?
well that gives me an excuse to build a rock krawller :D
I will NOT be making mods to the 318 headers and carburetor at the most
RMS
Post by RMS »
np420 1st gear = 6.68 np435 1st = 6.69
230 @ 800rpm produces about 130 fpt I couldn't find any numbers for a 318 below 2000rpm
I know a 318 produces way more power than a flathead but does it make it @ the right rpm ?
bouncing the truck and slipping the clutch @ 2000rpm to avoid "flash out" when on a steep hill or stuck in a hole is a great way to snap an axle. :P
with the t case only having 1.96 to 1 in low im looking forward to crawling around with the 265 @ 400rpm.
im not a v8 guy and will always push for flatty mods.....are you running your flathead with the stock comp ratio of 6.66 to 1 ? .080 off the head will bump that 230 to over 7.5to1 and give you a noticeable improvement for like $80
now a 413 with a np535 or 540 set up with 7to1 1st and od would be cool in a m37...granted I would need that 4.88 14bolt in the back
52PLOWERWAGON
I also read something about a Chrysler slant six I would prefer a 6 but the v8 seems like the easier way to get big HP
52PLOWERWAGON
so whats it take to put a slant 6 in The M37
RMS
Post by RMS »
52PLOWERWAGON wrote:the v8 seems like the easier way to get big HP
it sure is. for me and how I use my truck a short stroke under square(?) (bigger bore than stroke) v8 is not up to the task and would require a 3 or 4spd atlas with a low of 4to1 to be comparable to the 265 @ 400rpm in low 1.96.
if I was looking at a swap for a m37 I would be looking for a long stroke long rod engine.
chrysler 265 l head 3.438in bore x 4.75in stroke.... 218hp @ 1600rpm
dodge 230L head: 3.25 x 4.63
cadi 500: 4.3 in bore x 4.3 in stroke
olds 455: 4.126 in bore x 4.25 in stroke
chev 454: 4.250 in bore and 4.0 in stroke
dodge 413 high deck : 4.18in bore x 3.75
dodge 318 3.91 x 3.312
I don't want to be screaming at @ 5000rpm drinking back 6mpg doing 70mph in 4th
I would rather cruse in my 6000lb barn door lugging along @ 16~1800rpm doing 65mph in a .73 or .68 fifth
W_A_Watson_II
I was taught from a very young age that you don't ride or slip the clutch, except to back up to hook up to a piece of equipment that needs a slow finesse. The clutch pedal is either in or out, I brake my axles with raw power and trying things I shouldn't. I do love a slat 6 though!
Will
52PLOWERWAGON
what about an older hemi ?
I think that would be good lookin under my hood 8)
at this point I don't care what I put under my hood as long as its a mopar product and it gets about same mpg as a 230 flatty
