BeadBuster XB-450
BeadBuster XB-450
Anyone used this device on Budd rims and mil tires?
https://www.youtube.com/watch?v=wS8xGEmedik
The video shows a chap working on an ATV rim, but the company's webpage indicates that this device will work on 4X4 tires.
Rob
Rob
Re: BeadBuster XB-450
Hi Rob,
I've never used that tool, but judging by what it took to break the beads on a couple of 65+ year old NDTs on Budd rims..........I think those old tires would laugh at that tool. But like I said.....I've never used it first hand.
That looks pretty good. Beats jumping up and down on the tire or using a Hi Lift jack or even a fork lift and a heck of a lot safer then running it over with a 5 ton tractor . Of cause I don't recommend you do any of these things......
sAL
sAL
1954 M37 WO/W
1969 M101A1
1969 M101A1
I have to agree with Bob on this one. The last 9.00x16 that I dismounted was fused to the rim, and I think this tool would have broken before it budged that tire. My manual impact bead breaker just bounced off. I finally had to cut the tire off (carefully) with a Sawzall.w30bob wrote:Hi Rob,
Trial on hold until further notice due to administrative issues.
I would be afraid it would damage the split rings as it uses them as its fulcrum. I have several home made bead breakers that work with various levels of ease or success that don't ever touch the wheel itself. The easiest to make is the "garage stud" bead breaker. You bolt a long 2x6 to a stud a few feet up from the floor. Another 2x6 is bolted to that about 2' out and it is the breaker. Put your heaviest friend on the end to push down.
Liberal soap and a 36" duckbill. In 40 years of M37's, Dueces, and 5-tons, I haven't had a wheel I couldn't break down with that and a couple irons.
Dennis aka PoW
Dennis aka PoW
Well, this little tool is just too little to handle the M37 rims. It cannot get a safe grip on the inside of the rim and the foot does not reach in far enough - it should touch the rim. When deployed as instructed, the tool either pops off (with some force) or only pushes down on the casing. I will be modifying the tool to extend the arm that grips the inside of the rim, and by lengthening the "shoe" so that it reaches the inside lip of the rim. More to follow.
The old way, tried and true will eventually work. Tire irons and a mallet will get you there. But, since my time has some value I choose to take it to a local tire shop who do industrial stuff and have them break them down for me. $15 a wheel and they will dispose of the junk tire residue. Once they have been broken down and cleaned up, the next time is easy with hand tools. Just be sure the rim and ring are in decent shape and seated properly when inflated. The usual chains or cage and long hose to a remote inflator will keep you safe.
I am about to paint and mount some tires on my Budds rims. I have never done this, and am a little nervous about it. I intend to mount only the lock ring first, to make sure it fully engages the rim before mounting a tire. My main question is, is the mounted tire safe once it is inflated, or do you need to be careful with it while it is on the truck? Does anyone have experience with lick rings coming off after the wheel is on the vehicle?
If you're licking the rings, you should try some tire lubricant instead.ZGjethro wrote:I am about to paint and mount some tires on my Budds rims. I have never done this, and am a little nervous about it. I intend to mount only the lock ring first, to make sure it fully engages the rim before mounting a tire. My main question is, is the mounted tire safe once it is inflated, or do you need to be careful with it while it is on the truck? Does anyone have experience with lick rings coming off after the wheel is on the vehicle?
If the lock ring and rim are in good condition; if the lock ring, tire, flap, and tube are installed correctly; and if the tire is successfully inflated with safety chains or in a tire cage, then you shouldn't have to worry about it once it's on the truck. There are several good threads here about how to do this work.
It's possible for a wheel assembly to degrade in the field from corrosion or damage, to the point that the lock ring would explosively fail, but uncommon. Regular inspection should help prevent it.
Remember, hundreds of thousands of these rims were in use on thousands and thousands of military trucks, in all climates and in severe conditions. Most of us don't subject them to anywhere near the amount of abuse that they were designed for.
