Spark plugs
Gerry
Spark plugs
Post by Gerry »
Can you buy the waterproof plugs local or do you have to use one of the military vendors.
Gerry
53 M37
Lifer
Post by Lifer »
Your local auto parts store probably won't have them on the shelf, but they can order them for you. They are a bit pricey when compared to "normal" spark plugs, but you can get 'em.
gwalker
Post by gwalker »
If you buy at a parts store I know with Champion you have to get them in a 10 pack, not sure if Autolite has that qty. requirment. Champions are more than Autolites, but they are plated nice an the Autolites arent, they get rusty looking.
68 M-715 MVPA# 2710
Gerry
Post by Gerry »
Thanks for the info.
Does anyone have a # to order by.
Gerry
53 M37
monkeymissile
Post by monkeymissile »
I believe the Champion equivalent to the Autolite #2243 is stock #588, part #XMJ14
hope that helps
1953 Dodge M43
Fail often to succeed sooner
Gerry
Post by Gerry »
Gerry
53 M37
