Gas tank install ?
Tom P
Gas tank install ?
Post by Tom P »
My M never had a gas tank in it. It had a homemade tank in the bed.
I'm finally getting around to install a nice tank I got from MWM a Long time ago and make it right.
It did have the lower straps and upper supports still mounted to the front angle cross member.
No bolts in the rear cross member, so my question is how long are those bolts?
I know they are 7/16-20x?
TGP
"47" WDX WW
"52" M37 WW
"54" Willys M38A1
"65" M35A1 WW
To Many Others
vtdeucedriver
Re: Gas tank install ?
Post by vtdeucedriver »
The bolt length should be listed in the parts book.
http://linehaulrvn.tripod.com
1951 M37
1954 M37
1953 M62
1967 M54A1C
1968 M54A2C
1968 M52A2
1966 M151A1
Tom P
Post by Tom P »
Thanks But my parts book: TM P-2320-212-20P
Page 40 shows everything but the two bolts, It shows two nut/washer for the front end of the straps,nothing for the rear.
Don't list anything else on page 32,33.
I was hoping someone would know. If I have to I will pick up several lenghts starting at two inch I guess.
TGP
"47" WDX WW
"52" M37 WW
"54" Willys M38A1
"65" M35A1 WW
To Many Others
w30bob
Post by w30bob »
Tom,
ORD 9 lists the screw size as 7/16-20 x 1 1/4.
Tom P
Post by Tom P »
Thanks!
That's what I needed.
TGP
"47" WDX WW
"52" M37 WW
"54" Willys M38A1
"65" M35A1 WW
To Many Others
greeno
Post by greeno »
If not purchased already (and you're not going for 100pts) buy longer bolts. Makes installation WAY easier. 1 1/2" is what I used.
M37
YEAR: 1954
m37jarhead
Post by m37jarhead »
I put a new/reconditioned tank in my M a few months ago.
Also used new webbing on the metal straps. The extra
thickness on the new webbing made for a son-of-a-gun
to get the bolts started. So I got some longer bolts started
and sucked everything up into place. After a few weeks the
webbing had collapsed enough to replace the long bolts with
original. As mentioned: long bolts, short bolts... probably
doesn't amount to a hill of beans.
Jerry
Past Pres
Member: MVPA #26600
Member: NRA
59 M43, '76 M151A2, '86 CUCV,
'43 GPW, 416 & 101 trailers.
