Hood/Cowel weather stripping
ken mcculloch
Post by ken mcculloch »
Does anyone have a picture of what this weather stripping is supposed to look like? I received some material that is simular in texture to the rear fender welting material, but with a slightly different profile. Is this correct? I assumed this would be a rubber seal. If this is the correct part, how does it get installed to the cowl? Glue, screw, rivet?? Not finding any info in the TM's on this.
thanks, Ken
Tuko
Re: Hood/Cowel weather stripping
Post by Tuko »
it actually gets nailed in with 1/2" or so spiral shank nails. Ill go grab a pic.
51 Dodge M37 W/W 4BT/NV4500
My G741 Registry Entry
Tuko
Post by Tuko »
heres a pic, I bought mine from VPW they call it hood/cowl Lace:
DAP
Post by DAP »
if you don't care about originality you can pop rivet it in place. I used countersunk stainless screws with wide countersunk finish washer. Here is an old timer trick - clean the cowl lace real good (thinner if you dare) and then take black GE Silicone II and mash it, work it into the fabric weave until the fibers are encapsulated with it. Wipe off all excess. Let cure several days hanging in air and install. The cowl fabric will not rot and give you a good flexible seal. It almost looks original unless someone sticks his nose right up to it.
1962 M37B1
rectangular window hardtop, converted to Hercules 4 cyl diesel-intercooled & turbo charged, 12V, disc brakes
1962 M116A1 Generator trailer
1964 M101A1 3/4 ton trailer
