I Think My Cock is Missing!! Yikes!!!
jim lee
Re: I Think My Cock is Missing!! Yikes!!!
Post by jim lee »
No, think about it. If your going to submerge that truck you need to seal off the fuel vent line or your going to get water in the fuel. A fuel vent line shutoff makes sense in this case.
-jim lee
W_A_Watson_II
Post by W_A_Watson_II »
jim lee wrote:No, think about it. If your going to submerge that truck you need to seal off the fuel vent line or your going to get water in the fuel. A fuel vent line shutoff makes sense in this case.
-jim lee
That fuel vent line routes right into the fuel filler neck for venting, the only way it gets water is if water gets past the fuel cap.
Will
1946 Dodge Power Wagon
My 1953 Dodge M37 WEB Site
jim lee
Post by jim lee »
And with the fording kit, the water will be over the cap, by quite a bit.
-jim lee
jim lee
Post by jim lee »
Hey look at that, I been promoted.
First time
-jim lee
powerwagontim
Post by powerwagontim »
I believe the illustrated valve is the tank drain valve. The early trucks had them, they are located at the lower rear edge. They require a wrench to open and they dont drain fast. There is also a drain plug in the bottom.
Tim
w30bob
Post by w30bob »
Hi Tim,
I think I've gone about as far as I can go in terms of researching this one......and I think you're right......it's the tank cock just mislabeled in the TM. Thanks for all your inputs and if I find out anything contrary to this......or find an M with a cock on the vent I'll let you know.
m37jarhead wrote:
w30bob wrote:Bert.....the sad part is I'm old enough to know who Dr. Ruth is. :( :(
Hey.... Dr. Ruth is my younger sister !!
JB
Jerry,
I would love to hear the conversation around the table during the holidays. :shock:
