Hello everyone, Matt here. I purchased a 1953 M37 and registered it here in August last year. I got it running at that time by replacing the points, etc with an electronic ignition module. I had other projects to finish so I put the truck on hold until two weeks ago. The previous owner had sandblasted and primed the truck years before I got it so I have no bumper numbers. Is there any way to find out what they were? I would be interested in the service history of the truck. My other question is about the engine tag. It says it was overhauled 6-8-64 at AN.AD. What is AN.AD.? Bore says 000, mains is stamped 10 under label -10, and rods is stamped 30. Any ideas on what that means would be appreciated.
Thanks in advance
New member first question
Re: New member first question
Welcome to G741, the best Dodge M37 info. site on the net. Your engine tag indicated it was overhauled on May 8th 1964 at Anniston Army Depot Alabama. http://www.anad.army.mil/aboutANAD.shtml The 000 indicates a standard cyl bore, The crank's main bearings were turned 10 thousandths undersize and the rod journals turned 30 thousandths under. How does the engine operate? No knocks or smoke may indicate a good solid rebuild with no need to worry about it unless something else hints at a need to tear into it. Good luck and again welcome to our group, post some pictures when you have time... we love M37 "Porn"
That is exactly what I needed to know, especially the location of the rebuild. The truck seemed to run ok but didn't idle. I am guessing that had to be a carb issue. I tried uploading pics but didn't work.
Thanks again
Thanks again
Glad to have you with us, Matt! Great group of folks here ready to answer your many questions!
- m37jarhead
M:
Don't forget to try a "search" on this site for almost any M37 info. that you're looking for.
Believe me, there's volumes and volumes of info. on everything M37.
JB
JB
Past Pres
Member: MVPA #26600
Member: NRA
59 M43, '76 M151A2, '86 CUCV,
'43 GPW, 416 & 101 trailers.
Past Pres
Member: MVPA #26600
Member: NRA
Welcome Aboard Matt!
Welcome to the site Matt, we are looking forward to seeing your project and helping answering questions when they arise.
I do not have bumper numbers either. I was hoping to find past history also. Is there another way?
Mdevil,
Here's how to find out what your bumper numbers were with just a serial number.....I haven't tried it myself, but I'm cutting and pasting this response from your same question elsewhere in this forum.
Re: Tracing M37s
by 52 M-42 » Thu Dec 20, 2012 4:17 pm
Hi Marine,
Over on another website called Steel Soldiers there is an ongoing thread named "2012 vin info thread". A gentleman over there apparently has access to a lot (not all) old records for old military trucks. He will look for your serial number and post what he finds, if he finds anything,
It might be worth a try to see if he can help.
52 M-4252 M-42
Private message
Re: Tracing M37s
Hi Marine,
52 M-4252 M-42
Private message
