What is the steering knuckle rebuild procedure? I am rebuilding a '53-'54 from "scratch" and have the left steering knuckle put back together but I don't have the torque values for the bolts or for the tapered cone preload.
Any help would be greatly appreciated!
Steering knuckle rebuild procedure?
- PVT
Re: Steering knuckle rebuild procedure?
the Canadian eme manual states that the knuckle is to be shimmed with the upper bearing cap bolts tightened 60 to 80 foot pounds creating an oscillating preload of the knuckle at 25 to 30 foot pounds
i think the book is wrong and it should be 25-30 inch pounds.
hope this helps
I've heard of guys running two bearings in the knuckles and that it makes the truck steer easier. has anyone tried this ?
hope this helps
it is 25 to 30 foot pounds. some books say 27 ft lbs to be exact. some run 2 bearings but not recommended for offroad. ther is a reason all closed knuckles are set up with the bronze cone on top. strength and stability.
- PVT
Cool. I'm not too far off. I'll re-torque the cap bolts and recheck.
Thanks!
Thanks!
This may be useful if you are winging it. Thanks to Paul for this and many other interesting articles on his site.
Jess
http://imageevent.com/moosecreekmaple/steeringknuckle
Jess
- PVT
I'm having trouble and need someone to outline the actual porcedure or tell me where to find the procudure. PLEASE!!!!!
Thanks in advance.
Thanks in advance.
is this what you need?
- PVT
Yes, that is what needed! What manual did that come from?
1953 Canadian D144 eme
