antenna mount
rtkjmk
antenna mount
Post by rtkjmk »
Does anyone know the correct location for the AB243/G mount on the L/S of the bed ? I have a general idea of the location , above the knockout , but does it cover the Bow strap mount ? I want to get some what close BEFORE I start drilling HOLES in my bed . :? bob k
WarrenD
Re: antenna mount
Post by WarrenD »
Can't say if mine is correct, but it looks good!!
The bottom of my bracket is 1" above the highest point of the tie-down cleat.
rtkjmk
Re: antenna mount
Post by rtkjmk »
Thank you for the pictures , I just wanted to be sure before I started drilling holes in the bed . I picked up the 3 antenna sections yesterday from one of the people in the club , he has a ton of radio stuff and he is getting out of MV's . He has the whole radio truck set-up , would look good . Possiable future purchase ? thanks bob k :D
WarrenD
Re: antenna mount
Post by WarrenD »
Hmmm...... I'm looking for a RT-524 and MT-1029 base for my guntruck....
52 M-42
Re: antenna mount
Post by 52 M-42 »
There should be knock-outs for 3 of those antenna mounts in your bed already. You should just be able to knock them out and start mounting your antenna brackets. Specific antennas for specific radios go in each location; it all depends on what "family" of radios you are running.
You might want to do a little more research before you randomly start punching holes or mounting antennas.
Just a suggestion. :D
52 M-42
Re: antenna mount
Both of my beds had knock-outs for the wiring but nothing for the actual AB243 bolt holes (6), so I leveled mine up against the bottom-front of the bow strap mount, leaving enough room for the strap to flip up and down properly.
Re: antenna mount
Warren and Gary,
Can you guys snap a picture inside of the truck bed and out when you have a chance? I picked up a mount at Iola and when I looked at the bed sides I only found the knockout for the antenna wires. Which side of the truck bed is yours mounted on? Is there loose strap steel plates mounted on the inside of the bed to make it more rigid?
WarrenD
Re: antenna mount
Post by WarrenD »
Mine is on the left side. I'll have to look, but I don't think I can see everything with the armor box in, I think some of that area is behind the armor.
rtkjmk
Re: antenna mount
Post by rtkjmk »
I mounted mine today , just below the strap mount on the left side in front of the wheel opening . You do need the 2 steel plates inside the the bed to stiffen up the mount. I made mine out of 1/4" x 1" steel . Looks like it was always there . :D Bob K
Re: antenna mount
Bert,
I'll try to get one posted on Wednesday-last chance I'll have-vacation starts Thursday so I'll be off-line for a few days. Mine is on the driver's side.
Re: antenna mount
Sorry it's late but here you go Bert:
AB243 outside.JPG (18.07 KiB) Viewed 2203 times
AB243 inside.JPG (18.21 KiB) Viewed 2203 times
52 M-42
Re: antenna mount
Post by 52 M-42 »
Actually, there are 4 locations on the stock bed for antenna mounts. Basically there is one in each corner (roughly in the corner). My truck has 3 antennas right now and I'll probably add number four when my radio sets are working (I've got almost all the parts for the 3 big A/N GRC old family big sets - the -3, -5, & -7 plus a GRR-5). If anyone needs pictures of locations I can PM pics to email addresses, but I can not get pics to post to this site (Steel Soldiers is no problem - go figure).
52 M-42
Re: antenna mount
Thanks for posting the pictures Gary. It looks to be mounted higher than I thought. I will stare at it more this evening.
52 M42,
Could you post them on the SS site? I will chime in there.
52 M-42
Re: antenna mount
Post by 52 M-42 »
I have had no luck whatsoever posting pics to this site :? . Where on the SS site would you like me to post them?
I can email the pictures to Bert if he'll send me an email (I've PMed him mine).
Hope it helps.
52 M-42
m37jarhead
Re: antenna mount
Post by m37jarhead »
Yeah.... what's with all the difficulty in posting pic's on g741. I can't figure it out.
Tried following the tutorials but after the first sentence or two they're talking in
a language I don't understand.
Sure would be nice if posting pic's was a lot easier. We might see more pic's !
Did I say we might see MORE pic's.
JB
Past Pres
Member: MVPA #26600
Member: NRA
59 M43, '76 M151A2, '86 CUCV,
'43 GPW, 416 & 101 trailers.
