wiring harness
wiring harness
Who has the best complete replacment wiring harness for the M-37?
DA Supply Weenie
President Michigan Military Technical & Historical Society Museum
http://www.mimths.org
1942 Ford GPW
1942 Chrysler Fire Pump
1943 Hudson Invader
1944 WC-52
1951 M100
1952 M-37
1985 Dodge W-150 (Ex-Air Force line truck)
1942 Ford GPW
1943 Hudson Invader
1944 WC-52
1951 M100
1952 M-37
- CPL
Re: wiring harness
My only experience is with Vintage Wiring of Maine. Just received mine last month and it is TOP SHELF! Made to order too!!
Re: wiring harness
May I ask what the damage was for a complete new harness? I've got a rats nest for wires, but its running...
M37
YEAR: 1954
YEAR: 1954
Re: wiring harness
The harness is just plain brittle and has more repairs than I want to deal with. I prefer to not awake to find my garage engulfed in flames from a random short.
VWoM was my top choice; the harness I got from them for my GPW was right on. Do they include all the cannon plugs and Douglas connectors with theirs?
DA Supply Weenie
1942 Ford GPW
1943 Hudson Invader
1944 WC-52
1951 M100
1952 M-37
1942 Ford GPW
1943 Hudson Invader
1944 WC-52
1951 M100
1952 M-37
- CPL
Re: wiring harness
The harness from VWoM was spot on. It had all the connectors (less the plastic inner pieces--you save those from your old harness), along with a new turn signal set up! Plus a great wiring diagram, printed on larger paper for those like me that have "older" eyes. The price is reasonable considering the work that goes into making the harness and what you get. I couldn't be happier with the product.
Re: wiring harness
"...find my garage engulfed in flames from a random short."
I believe any vehicle that is 60 years old should have a battery disconnect switch. I turn my batteries off unless I'm actually in or working on the truck. It is very cheap to install and might just protect your garage from conflagration.
RICK
M 152 CDN
M 56 (V41)
M 152 CDN
M 56 (V41)
Re: wiring harness
Even though I have all new VWofM Harnesses, I still remove the series jumper from the 2 battery's when the truck's not in use.
Sal
Sal
1954 M37 WO/W
1969 M101A1
1969 M101A1
Re: wiring harness
Already burned up one M37 from an electrical short and not wanting to go thru that again I installed this set up, the relay disconnects the batteries common ground disabling the entire electrical system eliminating short circuit fires and dead batteries.
Re: wiring harness
Some have used the M37 Greek take-out harnesses that Sid Beck was selling a few years back - they come up for sale on occasion if you are looking for function over originality.
'Tanner'
'Tanner'
Re: wiring harness
Has anyone bought one of the Vintage Power Wagons' harnesses?
DA Supply Weenie
1942 Ford GPW
1943 Hudson Invader
1944 WC-52
1951 M100
1952 M-37
1942 Ford GPW
1943 Hudson Invader
1944 WC-52
1951 M100
1952 M-37
Re: wiring harness
Chris,
If you are looking to customize the harness for an electric fuel pump or electric wipers I don't think VPW harnesses would be a option unless you did the customization yourself.
I bought the VW of M harness and had him add exactly what I wanted.
Re: wiring harness
I am going straight stock, I was just wondering what the ones VPW sold were, new aftermarket, NOS, re-boxed VWoM........
DA Supply Weenie
1942 Ford GPW
1943 Hudson Invader
1944 WC-52
1951 M100
1952 M-37
1942 Ford GPW
1943 Hudson Invader
1944 WC-52
1951 M100
1952 M-37
Re: wiring harness
Chris. Before you Go Straight Stock with a new harness. Better check with your DMV to see if you need directional's to pass inspection. Where I live any vehicle 1952 and newer has to have them. So when I had my harness made I had to have it made with them.
Sal
Sal
1954 M37 WO/W
1969 M101A1
1969 M101A1
Re: wiring harness
Here in Michigan, the DMV does not care at all
DA Supply Weenie
1942 Ford GPW
1943 Hudson Invader
1944 WC-52
1951 M100
1952 M-37
1942 Ford GPW
1943 Hudson Invader
1944 WC-52
1951 M100
1952 M-37
Re: wiring harness
Does anyone have the instructions that come with the Sid Beck Greek wiring harnesses? I have a set and no instructions. Is it possible to post or email me a copy.
Thanks!
I'm new to the board.
Best Regards,
John
1963 M37B1 RESTORING.
Thanks!
Best Regards,
John
