Cargo bed bracket
Cargo bed bracket
Would someone be able to give me the measurements for the cargo bed bow tie down bracket, I just picked-up the HF compact bender and would like to try to bend up this bracket. Thanks.
Re: Cargo bed bracket
What measurements do you need? I currently am restoring one and am working on the bed at present.
Phillip
Phillip
Snowdad,
I need the measurements of the bracket that goes on the side of the cargo bed just above the tool compartment that is used to tie down the cargo bows when they are not in use. It looks like a draw handle made out of flat stock.
Thanks, T.R.
Thanks, T.R.
Give me till tomorrow. I will take measurements and post a pic or two. Will either side do?
Phillip
Phillip
I think both sides should be the same, or am I wrong. The bracket is close to the top of the bed rail and runs parallel with it. Pictures would be helpful.
Here are some pictures of the bracket.
5 1/2" overall length
7/8" overall height 3 1/4" inside of the bracket width.
You can measure the knockouts on your truck bed for bolt center locations.
Bert, thanks for the pictures and measurements that is what I needed. Now I can try out the new bender. Thanks.
Your welcome, Make sure to post your finished bracket pictures.
Well I tried to make the brackets yesterday, the HF bender will only make a 1.25" back-to-back bend. So I will have to find a different bender or someone that has two brackets that they can part with.
I know I have one spare, and might have two-I can check on Wednesday and let you know.
