Defroster Tube
m-11
Defroster Tube
Post by m-11 »
Can someone tell me the diameter of the knockout panel on the dash that is next to the glove box? I believe it was used for installing the defroster tube. This area was hacked up on my truck so I'm going to repair it to the point that I will be able to install a heater and defroster system at a later time. If anyone has a photo of an original defroster tube installed that will show me how much of the area behind the tube is actually exposed that would help too. I'd hate to spend alot of time on the area if you won't see it after the tube is installed.
paul
Re: Defroster Tube
Post by paul »
if you look at the first page of my build tread you should get the picture you want, they are the same size as a clothe drier tube i believe, i can take a mesure tomorow unless someone has it in memory
m37jarhead
Re: Defroster Tube
Post by m37jarhead »
Just measured mine. 4 and 1/8 " diameter.
Hope that helps.
JB
Past Pres
Member: MVPA #26600
Member: NRA
59 M43, '76 M151A2, '86 CUCV,
'43 GPW, 416 & 101 trailers.
m-11
Re: Defroster Tube
Post by m-11 »
Thanks guys. Here's a photo of what I'm dealing with now.
Joe
Re: Defroster Tube
Post by Joe »
Wow, it looks like somebody cut it out with an axe!
m-11
Re: Defroster Tube
Post by m-11 »
I'm going to clean up the damage, build a flush patch with the correct size hole for the defroster tube. I'll weld it in flush to complete the repair. The rusty white box under the dash was the heater.
Sal
Re: Defroster Tube
Post by Sal »
It just amazes me to see what some people would do to a truck... :shock: :shock:
Sal
:mrgreen:
1954 M37 WO/W
1969 M101A1
Glenn
Re: Defroster Tube
Post by Glenn »
m-11 wrote:I'm going to clean up the damage, build a flush patch with the correct size hole for the defroster tube. I'll weld it in flush to complete the repair. The rusty white box under the dash was the heater.
Do you plan to use the original type defroster sheetmetal duct? The one that is bolted on? If so, I suggest getting that first. Looking at your picture I believe it will cover up entirely the jagged mess you have, and will save you that bit of work. I have one I haven't installed yet so can't say for sure though. If you had one you could test fit it.
m-11
Re: Defroster Tube
Post by m-11 »
Glenn,
I'll take a measurment of the damage and post a photo. I don't have an original tube but it is in the plans to install an original heater. I think I'll still have to do some sort of repair so I can attach the duct.
m-11
Re: Defroster Tube
Post by m-11 »
Here's the size of the damage.
Glenn
Re: Defroster Tube
Post by Glenn »
Here hold my beer, I'll make that speaker fit. :shock: Yeah, you might as well go ahead and patch it right since now is the perfect time to do it.
m37jarhead
Re: Defroster Tube
I have an original defroster tube and can take pic's and/ or send you measurements if you need of the tube and the hole placement.
Send a personal email or call 480-497-9722
JB Gilbert,AZ.
Past Pres
Member: MVPA #26600
Member: NRA
Gerry
Re: Defroster Tube
Post by Gerry »
Gerry
53 M37
cuz
Re: Defroster Tube
Post by cuz »
Gerry's defroster.jpg (235.44 KiB) Viewed 2531 times
Master Yota
Re: Defroster Tube
Post by Master Yota »
Perhaps a dumb question, but how does one get to the window locks with the defrost tube on? Does it hinge downward at all? Or is there enough room to get hand between it and the window?
Ray
1953 CDN. M37
1954 CDN. M152
