Mystery Line & Fitting???
Tim Powell
Post by Tim Powell »
Hey Crew.
I think I have my fuel problem solved and now am on to the next problem/situation if you prefer! I found a 7/16" steel line with an inverted male flare fitting under the carburetor? There was a worm drive hose clamp hanging loose back on the line a ways?? Anybody know if this was some sort of a blow-by line?? I'll try and attach a shot of it. Thanks in advance!
Tim, Lori & Mr. Bear!
DSCF8782 (400 x 300).jpg (29.6 KiB) Viewed 1268 times
M37UK
Re: Mystery Line & Fitting???
Post by M37UK »
Tim, is the line actually attached to the bottom of the carb or does it make its way over to the distributor?
Stu
MVT UK
SMVG Scotland
Tim Powell
I did not follow it around to the opposite side of the engine but I will. It is not attached to the carburetor! There is another fitting on the intake manifold that is plugged off, I'm wondering if there was some sort of a check vale for crankcase ventilation? :?:
monkeymissile
Post by monkeymissile »
it looks like the line to the (missing?) PCV?
http://inlinethumb18.webshots.com/10897 ... 600Q85.jpg
1953 Dodge M43
Fail often to succeed sooner
Tim Powell
I've been doing a photo search of an engine rebuild and can't really find the picture I'm looking for. I do think it's some kind of a PVC valve line and the valve is missing??
monkeymissile
Tim Powell wrote:I've been doing a photo search of an engine rebuild and can't really find the picture I'm looking for. I do think it's some kind of a PVC valve line and the valve is missing??
Tim, do you have any of the manuals?
1953 Dodge M43
Tim Powell
I do not have any manuals yet! Yet being the key word! Thank you for the picture that is exactly the part/valve I'm missing!!
The Mystery Part I'm Missing!! Thank You!
Crankcase vent!.jpg (81.38 KiB) Viewed 1220 times
monkeymissile
glad I could help. It's not often I get to since I'm fairly new to all this myself.
I got all the manuals on a CD for about $20. I forgot the name of the outfit, but I'm sure someone will chime in....
have fun!
1953 Dodge M43
Tim Powell
NEW Crankcase Vent Valve
Fits Vehicle Type: B,C,D,E,F
(Note: 1/2” longer)
Part #RCVV27 $20
In stock @ Vintage Powerwagon, Fairfield Iowa! Thanks For All The Help Guys!
http://www.vintagepowerwagons.com/pdf/p ... engine.pdf
