They will be fine, they cut like any other drum, I had mine recut (prior to me fitting discs) and they worked a treat, the only thing I had to do was get a cone sleeve turned up so the larger hub diameter was accomodated. The main reason I went to discs was stopping power and parts availability being that I am in a somewhat remote location for M37 parts supplies and my drums were getting to their final cut anyhow.Master Yota wrote:powerwagontim wrote:When you had your drum turned, was it mounted on its hub? If not, it will make a really nice ashtray!
Tim
Are these drums different than all the other brakes drums that are turned without a hub? Is the center hole not round, or offcenter? What gives?
Regards - MM
