Fuel filler pipe assy
- PVT
I've removed and disassembled the cargo box and stripping,painting, etc. and I just realized that the fuel pipe is tin or solder coated. Is this to reduce corrosion or reduce possibility of static electricity or what?
- PVT
fuel filler pipe
Lifer,
Thats what I thought to, but I had one place I was trying to remove the paint that was really thick and I heated it with a propane torch and the surface melted just like the solder joints I used to make plumbing. I know I didn't get if hot enough to melt zinc which has a melting point about 300 degrees higher than tin.
Ron
Ron
- PVT
fuel filler
Lifer,
I like that- radioactive fuel filler. Hell, we can make up all kind of stories around that
Ron[/b]
Ron[/b]
It's depleted uranium so when you run out of ammo you can pull it out and throw it at them!
