starter removal
- SSGT
starter removal
Apologies in advance if I already asked this question (I DID search beforehand!). My starter has always been very sluggish, sometimes a minute or so would pass after stepping on the switch before the engine turned over (my batteries are good BTW). I thought it might be a dirty commutator or varnished brushes. Now it won't turn over at all and I want to pull the starter to inspect and service it.
Is this a difficult and time consuming task based on your experiences? Thanks.
1953 Dodge M43
Fail often to succeed sooner
- SSGT
- HingsingM37
A minute or so? That is most odd. Then it would just radomly crank? Let us know what you find. I'm curious.
- SSGT
no, it would then crank normally, albeit slowly, but eventually catch and fire up. Now it doesn't crank at all. I'll be sure to post my findings. Thanks.HingsingM37 wrote:A minute or so? That is most odd. Then it would just radomly crank? Let us know what you find. I'm curious.
1953 Dodge M43
You might need to get a starter wrench unless you already have one, the top starter mount nut is hard to get off without it.
The manual also states to unscrew the oil level gage pipe (dip stick) from the block and remove it and the gage to provide clearance when taking the starter out.
- SSGT
thanks for the tip about the wrench. I don't have one, what size?Carter wrote:You might need to get a starter wrench unless you already have one, the top starter mount nut is hard to get off without it.
1953 Dodge M43
Starter
I removed my starter when I replaced the starter switch. That was before I realized I could probably have replaced the switch without having to remove the starter at all. Well my problems started when I realized I couldn't remove the starter without removing the pressed in dipstick tube. You see my engine being an industrial 230, haa a pressed in tube. So, I had to remove the oil pan and drive out the tube then remove the starter, perform the two minute switch swapout, then reverse the procedure. What a hassle. Wound up cracking the dipstick tube because when I removed the starter the first time, I banged it into the tube from not knowing the starter wouldn't clear.
If you have the military screwed in dipstick tube this shouldn't be a problem.
If I were you I'd first try to swap out the starter switch, maybe that's the problem and not the motor.....
- SSGT
Re: Starter
That's not a bad idea, I'll start sourcing new switches. Thanks!Nickathome wrote: If I were you I'd first try to swap out the starter switch, maybe that's the problem and not the motor.....
1953 Dodge M43
The wrench I have is 9/16ths and 5/8ths and my GUESS is that it is most likely the contacts in the switch that are causing the problem and you might not have to remove the entire starter. They carry a lot of amps and sometimes burn out before the brushes and windings in the motor go bad.
- SSGT
that would save me a lot of time if it was just the switch! I will definitely check it out first and maybe just install a new one. Do you have a preferred source? I was going to check w/John at Midwest first. Thanks for the wrench info too...Carter wrote:The wrench I have is 9/16ths and 5/8ths and my GUESS is that it is most likely the contacts in the switch that are causing the problem and you might not have to remove the entire starter. They carry a lot of amps and sometimes burn out before the brushes and windings in the motor go bad.
1953 Dodge M43
I never had to buy a new switch, always had a good supply of M stuff on hand that I was given years ago when the NG maintenance unit I was a member of turned in all their issue trucks and then gave me all the parts they had on hand. I am sure John has some switches as well as all the other guys you hear about on this forum like Sid Beck, g741@ccwip.net Keep in mind there were 2 different switches used on those starters so be sure what you order is the same as what's on it now.
- SSGT
looks like he does have some, just checking on the style (I have an earlier truck). If the switch is at all serviceable, perhaps it just needs some attention....Carter wrote:I never had to buy a new switch, always had a good supply of M stuff on hand that I was given years ago when the NG maintenance unit I was a member of turned in all their issue trucks and then gave me all the parts they had on hand. I am sure John has some switches as well as all the other guys you hear about on this forum like Sid Beck, g741@ccwip.net Keep in mind there were 2 different switches used on those starters so be sure what you order is the same as what's on it now.
1953 Dodge M43
- SSGT
starter switch pedal alignment
saw on page 251 of TM 8030 that early model trucks can experience a mis-alignment of the starter pedal plunger and the starter shifting yoke. I'll check that out too
1953 Dodge M43
