Tranny ?
Gerry
Tranny ?
Post by Gerry »
Getting ready to check my tranny out before install. I noticed there is a small amount of play in the splined shaft. Is this normal?
Gerry
53 M37
Charles covered this one in detail recently-here is the post:
http://www.g741.org/PHPBB/viewtopic.php?t=2043
Gerry
Post by Gerry »
I will have a look
Gerry
53 M37
Gerry
Post by Gerry »
The play in the shaft is up and down, like a worn bushing not front to rear.
Gerry
53 M37
Better make sure your pilot bushing that goes into the end of the crankshaft is in good shape-that should help stablize the shaft from too much "up and down" action whenever the clutch is depressed.
Gerry
Post by Gerry »
I bought a new pilot bushing to install when I reassemble.
Gerry
53 M37
