batteries ??
TOM R
batteries ??
Post by TOM R »
ok now we got the box all finished and installed, what brand/size batteries will fit in it with a stock hold down? i don't care if they look original as long as they fit the stock tray :D
1945 t24/m29 weasel
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
The original batteries were the 2HN which are available through a few of the surplus dealers. If you want to pay the big bucks look into a set of Optimas. The military has basically switch over to them. I was at my armory last month and the one unit got issued a bunch of brand new 10kw and larger gensets and there from the factory were optimas. Also they had a FMTV that they were working on and they were putting in a set of opts also. Other than that I know that there is suppose to be a civy replacement for the 2HNs but I don't know the number. I'm sure someone will post up.
KenInGA
Post by KenInGA »
I've just got 2 standard "heavy-duty" NAPA car batteries, and they fit just fine. Don't slide around or nothing.
'62 M37B1- It runs AND stops!
TOM R
Post by TOM R »
the 2hn are still available new from our local batt wholesaler at $85 each, dad got 2 cheaper ones that were $90 for the pair that fit good enough think their dekas for an old falcon also used in old propane forklifits?
1945 t24/m29 weasel
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
pfrederi
Battery Civilian
Post by pfrederi »
22NF is the same size as the mil spec but the terminals are reversed. They are easy to find. I believe there is a 22SNF that has the correct terminal but they are much harder (read $$$) to find..
Paul f
peter e mark
Post by peter e mark »
I do love the optima batteries, I am convinced they crank better in cold weather too...
1952 M37 W/W
I purchased Interstate MT51's. This is the higher CCA version of the 22NF.
peter e mark
Perhaps the additional advantage of your choice is that that they may look more like the originals.....
1952 M37 W/W
