batteries ??
batteries ??
ok now we got the box all finished and installed, what brand/size batteries will fit in it with a stock hold down? i don't care if they look original as long as they fit the stock tray
1945 t24/m29 weasel
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
The original batteries were the 2HN which are available through a few of the surplus dealers. If you want to pay the big bucks look into a set of Optimas. The military has basically switch over to them. I was at my armory last month and the one unit got issued a bunch of brand new 10kw and larger gensets and there from the factory were optimas. Also they had a FMTV that they were working on and they were putting in a set of opts also. Other than that I know that there is suppose to be a civy replacement for the 2HNs but I don't know the number. I'm sure someone will post up.
Battery Civilian
22NF is the same size as the mil spec but the terminals are reversed. They are easy to find. I believe there is a 22SNF that has the correct terminal but they are much harder (read $$$) to find..
Paul f
peter e mark
- SSGT
- HingsingM37
peter e mark
- SSGT
