Ok, ok, so it's not really doing drugs... Neither am I!!
On the 2nd drive I was able to confirm what I 'thought' I was hearing. With my right ear deaf, sometimes I think things are different than they really are. The best I can describe it is when accelerating at 45mph I hear multiple "HUFF" (not a backfire). The engine lightly skips a beat but continues to develop RPMs.
Under 45mph, smooth...
Is that the Governor I keep reading about?
Any high speed (yea, right) jet adjustment on the carb I should look at??
Carburetor - Huffing above 45MPH
Re: Carburetor - Huffing above 45MPH
How far out do you have your choke pulled when all this is happening?
On mine I have to pull the choke out about 1/4" to get it to run smooth. Air is getting in somewhere, but I can't detect from where yet.
Choke isn't out, this happens at temp.
Rdinatal,
It's possible it's the governor. You can test it in lower gears and see if the behavior is reproducible. A search will kick up a bunch of posts on how to adjust the governor if that proves to be the case.
I've also seen a low float setting cause issues that were similar to a poorly adjusted governor. Again a search will help you out there. I'd suggesting setting the fuel level "wet" if possible as opposed to just measuring the float height with the needle closed.
It was the governor. Adjusted and no more huffing.
While troubleshooting it was revealed that two cylinders have really low compression. Not something that one wants to find...
Wanted to update on the low compression.
After some reading I decided to
- Change oil/filter
- Put Marvel MO in the gas and oil (cleaning ratio)
- Run for two tanks
- Change oil and recheck compression
The compression is now between 95-110psi. While not perfect, it's good. There's other items that need attention.
I have never done a compression check. Perhaps I should, based on your results.
