Solid State Voltage Regulator Adjustment
R1830
Post by R1830 »
Hi. After 6 years finally got my M37 Running and road ready.
When idling my voltmeter is showing high. I have a solid state voltage regulator. Is there an adjustment?
In Progress: 1952 M37CDN Teardown
Re: Solid State Voltage Regulator Adjustment
What is the voltage?
Have you verified that the voltage in the instrument cluster gage is accurate by comparing with a known good multimeter?
R1830
Post by R1830 »
It was showing 34 volts on my crappy multi meter so quite high. I’m going to double check with a better meter tomorrow. Could hear the batteries getting hot though so I think the gauge is accurate.
I should have also asked: original 24v system or converted to 12v?
Either way, 34v is high.
No way to adjust the solid state regulators that I know of.
R1830
Post by R1830 »
It’s original 24v but new harness and regulator. There is two adjustment screws it looks like inside the regulator.
mine for my 100 amp system puts out about 26 volts as I recall. hal
The SS 25A regulators have never been known as reliable, or as reliable as the original mechanical ones.
It is good they are interchangeable.
A 24-Volt system should charge at 28-Volts.
