M37 build from scratch
Turbothis
Post by Turbothis »
morning fellas!
ill keep it simple
i have machine/fab shop to build pretty much anything
i have grand Cherokee with 1 ton drivetrain i would like to put in something more special and tough
M37 stuff is expensive and tends to be rusted or missing!
i built some little jeep karts with pretty much no sheet tools so this will be pretty fun to use my new tools
what i have so far.......
my base is a 87 f150 frame and power steering box with a TITLE
i got a descent trail blazer middle row seat to use for a couple reasons. folding and goes flat too
all Cherokee drivetrain. 1 tons, lockers, 5.43 gears turbo I-6 w/ 6 speed fully semi automatic trans ect ect....
pic dump for attention
Re: M37 build from scratch
HI Turbo and welcome! You've done some nice work there; we'd love to see you scratch-build an M37!
Keep us posted!
Impressive work!
Turbothis
Post by Turbothis »
cool,
i got a factory hood coming off ebay
that is likely to be the only dodge part
i was thinking of using some semi truck doors
this would get me some modern features and be rust free?
cool rivet pattern and close to correct shape. the windshield would have the same rake angle though
Turbothis
Post by Turbothis »
i run a chevy 05 trailblazer 4.2l with a 72mm turbo
i am a huge fan of the 6 speed 6R80/HP26 trans and used one on this
the jeep was a tight fit so i think i can make some more room in the new rig
Turbothis
Post by Turbothis »
the only hood i found online off ebay
Turbothis
Post by Turbothis »
i built my baja style truck cab using all new tube and sheet skin. this will be the same style...
Turbothis
Post by Turbothis »
frame cleaned up
14 bolt rolled under
machined up some new lower link mounts
Turbothis
Post by Turbothis »
new crossmembers in
3 link for the rear almost done
motor position set
time to roll in the front axle
Good golly you don't waste any time, do you? Impressive work!
Turbothis
Post by Turbothis »
ya, needs to get done! lol
Turbothis
Post by Turbothis »
Turbothis
Post by Turbothis »
some pics of progress
my custom 25 gallon tank fits but just barely!
i plan on making the roof skin about 2" under the cage top so i have a structural roof rack to haul stuff
need to move the radiator/intercooler cross member up about 3"
Turbothis
Post by Turbothis »
used the metal brake some for the inner fender walls
also got the drivers side rock slider step thingy skinned in .085" diamond plate
Turbothis
Post by Turbothis »
also got the radiator/intercooler cross member welded in 3" higher
