Afternoon Gentlemen...
I just finished putting new tires & tubes on Fiona. I purchased ASTRO Military 9.00 X 16 tires and had them mounted by a truck tire center. Took the truck out for a short drive to get fuel and when I returned I noticed that the truck is running on only about 3 to 4 inches of tire. The tire states 125 psi cold and not sure how much the truck tire center put in them when they were mounted because my air gauge only goes to 50 psi... My questions are... Isn't that too much air for the load? Shouldn't she be running on more of the tire surface?
Thanks, Dennis
M-37 Tire Pressure
M-37 Tire Pressure
Investig8
1953 M-37
1952 M-38
1953 M-37
1952 M-38
- sturmtyger380
Re: M-37 Tire Pressure
So you mean that the area the tire is contacting the pavement is small?running on only about 3 to 4 inches of tire
This sounds like a heavy duty tire. The tire pressure on the side should list a max pressure - that's if you are carrying a heavy load. I have noticed that places that mount tires run the pressure up to seat the tire bead on the rim and then don't always lower it back down or just down to the max listed. Plus they err on the side of their safety and don't want you driving off and hauling 3 tons of gravel and blowing a tire cause they put it at 32 psi.
Normally you adjust your pressure for what diving you are doing and hauling. For the regular tires on my pickup I run around 36psi. But when towing a heavy trailer I go up to around 60psi (as listed on the side of the tire.)
Interesting story (Geezer alert!
Thanks for the input and the great story... I feel somewhat like an idiot after reading Nam Vet's reply because I then remembered that the tire pressure is plastered on the side of the truck just above the rear tire in many cases... Duh!!
Enjoy your week, I think my problem is fixed...
Dennis
Dennis
Investig8
1953 M-37
1952 M-38
1953 M-37
1952 M-38
