Cowl vent question
powerwagontim
Cowl vent question
Post by powerwagontim »
Hi Guys,
I assembled the cowl vent yesterday. When I close it, it centers nicely in the hole and bears great in the back but the front is 1/2" up. I have the link bar at the extreme of the adjustment length so should have the most pull down. I have played the the adjustment of the hinge as well but can not effect the tilt of it to lay down flat. What am I missing here? It would seem to get the vent where it needs to be I would need to slot the holes more but that seems extreme, I have to figure it worked when I took it apart!
I appreciate any input!
Tim
RMS
Re: Cowl vent question
Post by RMS »
keep fighting they are a pain. got one on my fist try another sits flat when closed but wont raise all the way and a third one moves its full range but sits crooked when closed .... got hours into it
mine had wear and elongation of the hole where the pivot pin was, so used a larger bolt to take up the slack. NV
Yep, one of the M37's little 'time requirement' things.
It will behave, eventually.
