Hi, how are you? I have a Dodge M37 that I bought with a very good Perkins 6, but I always had the idea of putting the original. Well, I got an engine that was put in a Dodge power wagon 200 also with 4x4 clear, it is armored and everything like the M37, but the engine numbers do not start with T245, but with R6WM3 -... .. Do you know anything about these engines ?, year, same horses ?, my consumption? etc?.
Thank you very much!!!
Carlos from Argentina
Engine R6WM3
Re: Engine R6WM3
Seems to have been an export only Dodge motor used in the Mowag GW 3500 4x4 Kommandowagen. The best I can do on specs are located here:
http://nufabi.de/php/mowag/1953-t1-4x4-gw3500.php
Re: Engine R6WM3
It's a T137 Dodge 230 L6 engine as Bob suggested used in the Power Wagon.
MOWAG T1 4x4 GW3500
Vehicle type:
Light military terrain vehicle
Year of manufacture Vehicle:
1953-1962
Year:
1953-1962
Country of origin:
Switzerland
Motors / driving performance
Engines
Years
Cyl./Vent.
Verd.
Bore x stroke
Displacement
Pmax
Spec. P
Mixture.
Mmax
Dodge T-137
53- ?:
R6 / 12V
7.25: 1
82.5 x 117.5 mm
3770 cm³
103HP
@ 3600 / min
27.3 PS / l
Carburetor
256 Nm
@ 1200 / min
Dodge R6WM3
? -62:
R6 / 12V
7.25: 1
82.5 × 117.5 mm
3770 cm³
113HP
@ 3600 / min
30.0 PS / l
Carburetor
274 Nm
@ 1600 / min
Tom
MOWAG T1 4x4 GW3500
Vehicle type:
1953-1962
Year:
1953-1962
Country of origin:
Switzerland
Engines
Years
Cyl./Vent.
Verd.
Bore x stroke
Displacement
Pmax
Spec. P
Mixture.
Mmax
Dodge T-137
53- ?:
R6 / 12V
7.25: 1
82.5 x 117.5 mm
3770 cm³
103HP
@ 3600 / min
27.3 PS / l
Carburetor
256 Nm
@ 1200 / min
Dodge R6WM3
? -62:
R6 / 12V
7.25: 1
82.5 × 117.5 mm
3770 cm³
113HP
@ 3600 / min
30.0 PS / l
Carburetor
274 Nm
@ 1600 / min
Tom
"47" WDX WW
"52" M37 WW
"54" Willys M38A1
"65" M35A1 WW
To Many Others
"52" M37 WW
"54" Willys M38A1
"65" M35A1 WW
To Many Others
Re: Engine R6WM3
a perkins in an m37
that truck must be a beast
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
1952 M37 FARM TRUCK
1941 WC RATROD
Re: Engine R6WM3
Thank you for your information!!!!
It is very valuable to me.
If I knew how to upload photos of the engine, I would show it to him.
